Need to wipe/corrupt damaged microSD card
Caporegime
18 Oct 2002
London
Yet again my S4 has broken another SanDisk microSD card. As with the first time all of my files remain on the card but I can alter them in any way; so I can't delete (I can but the files simply reappear) nor can I add any new files to the card.
SanDisk are fine with replacing the card but want the damaged card returned. However, the card contains many files of a sensitive nature. Other than stamping on the card several times, how can I nuke those files from the card before sending it back to SanDisk? I have tried several formatting solutions with no luck. Any ideas?
Boot into a live linux environment, mount the SD card and run sudo dd if=/dev/urandom of=/dev/devicename 4M
Edit: actually don't do the above if you don't know what you're doing as you might nuke the phone.
Where did you buy the card?
ebay/amazon reseller? If so, it's probably a fake, hence the problems.
This card is an RMA from SanDisk so I guess it's real. The first card was from a reputable online store.
There seems to be a correlation with Samsung Galaxy phones and SanDisk cards (fake ones could be part of the problem).
Fair enough
Which formatting solutions have you tried?
Windows, HP USB Disk Storage Format Tool, the phone's formatting tool and I think a SanDisk formatting tool.
Do you get a drive letter when mounting it in windows? I thinking if a DISKPART Clean might do the job.
The card works fine in the phone and on the computer. It just won't allow you to write/delete.
Quick Diskpart guide, make sure you do not wipe your own drives, there is no confirmation screen with diskpart and can cause you many a problem if you're not careful.
Open the CMD as admin, type diskpart.exe. A new cmd window should open running diskpart.
Type "List Disk" all the disks in your computer should show up. Identify your SD from the size. When you know what disk no. your SD card is, type "Select disk x" x being the disk number.
Once the disk is selected, make sure its right, type Clean. This will remove all information from the Disk. You may then want to format the drive again. You can do this through diskpart, but you need to specify different things, its usually easier to do it through disk management.
Last time i needed a replacement card from sandisk, all they required was the serial number and photos of the cut up dead card emailed to them.
