Need UBER fast mysql help
26 Jun 2003
North West
I have this query which works fine on most servers. But the host has mysql version: 3.23.58, which I dont think supports nested queries.
So how can I fix this query to not use a nested query?
Code:
$query = mysql_query("SELECT * FROM ".TABLE_PREFIX."roster
WHERE rosterid IN (SELECT rosterid FROM ".TABLE_PREFIX."team)
ORDER BY name ASC");
Thx
jd
try EXISTS instead of IN.
Try:
Code:
$query = mysql_query("SELECT * FROM ".TABLE_PREFIX."roster a
WHERE EXISTS (SELECT rosterid FROM ".TABLE_PREFIX."team b WHERE a.rosterid = b.rosterid)
ORDER BY rosterid");
Although that's DB2 stylee, it may work.....
That uses a nested query, which I cant use on thier version.
Is there anyway I can update the mysql version of does the provider have to do that?
Does this work?
Code:
SELECT r.* FROM ".TABLE_PREFIX."roster AS r
INNER JOIN ".TABLE_PREFIX."team AS t ON r.rosterid = t.rosterid
GROUP BY r.*
ORDER BY r.name ASC
The GROUP BY is a bit dodgy - you may need to list all of the field names in roster for it to work.
arty
arty said:
Does this work?
Code:
GROUP BY r.*
ORDER BY r.name ASC
arty
Yeh that seems to work fine atm, I replaced the * with the fields I wanted.
Thx
Ill let you know if it fails!
