Hi, i want to upgrade my ancient ps that i mainly play games on. Basically im looking to spend upto £400 for a motherboard, ram & cpu that is all i need, allready have a heatsink & os etc.
Thanks
Not sure what cooler you have, but if it is quite old then there is a good chance it wont fit the new CPU socket. If you order the retail CPU it will come with a cooler.
Also you will also need to reinstall the OS as you are changing the MB.
