NEED URGENT ADVICE
8 Oct 2008
HELLO PEOPLE,IM IN NEED OF SOME URGENT PROFFESIONAL ADVICE.IM LOOKING TO BUILD A PC OF MY OWN BUT NEED SOME ADVICE ON COMPATIBILTY.CAN YOU HAVE A LOOK AT THE LIST FOR ME TO SEE IF THESE PARTS ALL FIT RIGHT AND ARE COMPATIBLE,IF YOU SEE ANY REASON FOR IT NOT TO RUN THEN PLEASE LET ME KNOW THANKS a lot FOR YOUR HELP....
MSI K9A2 Platinum 790FX Socket AM2+ 8 channel audio ATX Motherboard
ATX 12v 1300 p4 switching power supply
Phenom 9850 Quadcore black edition CPU
PowerColor HD 4850 PCS+ Edition 1GB GDDR3 OC Dual DVI HDTV Out PCI-E Graphics Card
SATA II 250GB HARDDRIVE
OCZ 2GB Kit (2x1GB) DDR2 800MHz/PC2-6400 CL 4-4-4-15 PLATINUM XTC with LIFETIME WARRANTY
I HAVE THIS MEMORY AT THE MOMENT BUT AM LOOKING TO BUY THIS MEMORY
OCZ 2GB KIt (2x1GB) DDR2 1066MHz/PC2-8500 Reaper Memory HPC Edition Dual Channel Kit CL5
I HAVE PROBERBLY MADE SOME MISTAKES HERE OF COURSE AS IM A NOOBIE TO BUILDING PCS,SO PLEASE IF YOU COULD HELP ME OUT THAT WOULD BE GREAT.TAKE CARE.
I think its his spelling and grammar thats broke not his keyboard.
Although his shift key does appear to be stuck.
cleric , let me tell you something about this place, and life as a matter of fact.
people , given a chance will put you down for things like grammar , they are anal idiots who miss the point totally regarding communication.
you don't go around telling handicapped people to speak clearer as their way of speaking sucks.
im not claiming your handicapped, but you may as well be with grammar like that
well the op may have come off a 40 hour shift at the local hospital, but you laid into him with just as much thought as i gave you
yes but I made one little spelling mistake. My post wasn't full of bad grammar and spelling mistakes, half capitalised half not.
his post wasn't based on a vilification of someone who has bad grammar, yours was which makes it so much sweeter, and makes your sinlge mistake worth a thousand
Mind if I ask why you are sticking with AMD apart from familiarity? At this moment in time, Intel is the way to go in the majority of cases.
Also, and chance of having more detail about that PSU and hard-drive? They are two areas where a lot of people skimp, but really really shouldn't
