Out of sudden my PC stopped displaying image. I mean It is working and monitor is working, but it doesn't show anything! Could there be something wrong with my graphics card? like an overheating issue? How can i determine what is wrong?
-Asus GeForce GTX 275 896MB GDDR3 PCI-Express Graphics CardMore info required. What spec is your pc? What do you see on screen? Error mssge? Black screen? Do you get to bios screen? As much info as you can offer will help.
does your motherboard/processor have onboard graphics. you could use this to check if the PC is working or not.
i had a similar problem to this and it turned out that my PC had decided that it didnt need a VGA driver any more and threw it out. a quick update of the driver (with the graphics card disconnected) solved it
overclocking?!
on the back of ur pc other than where u plug in ur monitor cable is there another vga port that u can try, it see if the problem lies in ur graphics card.
what is ur order of booting?
nope the other port isn't working either =(
???? So I should take out the GPU???
Are there any beeps you can hear? Were there any beeps in the first place?
Surely the onboard graphics would be disabled while the graphics card is installed, so what the OP needs to do is remove their graphics card, then try the onboard graphics?
Wait for someone elses advice.
But this PC I built recently is my first ever PC, and when I installed the gfx card, it disabled the onboard graphics.
So to test your onboard graphics I am fairly sure you will need to take the gfx card out
