Need wireless external adaptor for ibook
6 Jan 2006
Midlands
Hi
im gonna go wireless soon and my old ibook doesnt have wireless. Is there a cheaper option than getting airport adaptor.
can someone recommend me a external wireless adaptor that will work with my ibook. im using mac osx 10.3 at the moment if that helps
thanks
ultim said:
Hi
thanks
I got a belkin pcmcia adaptor for an old powerbook, had to use a dlink utility to get it to work with wpa encrypion though, worked like a charm. I'll see if I can dig out the details.
Ibooks dont have PCMCIA slots. The internal airport slot is essentially a PCMCIA slot but im not sure that it will work with a normal card.
I have tried several usb adapters and they have all been flaky as hell with ox 10.3 and 10.4.
I really would reccomend biting the bullet and getting an airport card, they are expensive but they work flawlessly.
Aaron
