cokecan72 said:you want the Microsoft 360 VGA Cable
OcUK dont sell it but every game shop should![]()
cokecan72 said:either. if your monitor has a vga cable that screws in (some are fixed to the monitor) you can just plug the 360 VGA stright into the monitor, or you use the female to female converter you SHOULD get with the cable (i say should as there have been some people who didnt get one for some reason??) and just plug it into the end of the monitors VGA cable
hope this helps![]()
