Hi guys,
Not sure if this is the right place for this, so if it is not i do apologise.
Basically I have a wireless router, which is hooked up to my desktop (wired). Although I can connect to the conection with my laptop (wireless), it doesn't actually do anything and BT are bloody useless.
I've tried to connect to MSN messenger on my laptop and it does say Default Gateway problem when i try to repair the problem.
When i try to use internet explorer, it does not connect to any web page.
I can connect to my wireless network perfectly fine with my Nokia N95 8GB. :s
Any ideas what it could be?
Thanks guys.
Thanks guys.
