Neooffice problem
A2Z
A2Z
Permabanned
9 May 2005
Earth
Im posting this for a friend - basically he had a word doc, then downloaded neooffice and opened the word doc.
The doc has footnotes - and basically when you type anything after the last footnote number in the doc, the text is REALLY small, like the size of the footnote number, if you get what i mean...
How do you get it back to normal sized text?
Footnote text is meant to be small? :confused:
You should still be able to change the size of it manually though.
