- 15 Nov 2014
I just opened the task manager on my nephew's Windows 8.1 x64 and I noticed something running called "PRIVOXY"
I have never heard of it before so I clicked "End Task". I then tried to go back online using Google Chrome and got the following message "Unable to connect to proxy"
So when PRIVOXY is not running there is no Internet at all which is very worrying. I then decided to go into the control panel "Add remove Programs" but PRIVOXY is not there.
So I have looked online and discovered that although PRIVOXY itself seems to be a legitimate program some viruses do make use of it if they infect your machine.
So I do not know how it got on the machine but I need to get rid of it ASAP so any ideas would help.
