Nero 7 limiting burn speeds.
Caporegime
12 Mar 2004
England
My dvd-rw nec 3520 can only select 16x burn speeds in nero yet it is capable of 48x write speeds, what is the issue here? I have the latest firmware for the drive.
Are you burning a CD or a DVD? Your burner is probably capable of 48x in CD mode but only 16x in DVD mode - no burner can burn a DVD at 48x.
Could also be your media - if the discs are limited to 16x then you'll only be able to select 16x, whatever your burner is capable of.
