Nero 8.1.1.4 mp3/mp3PRO plugin bug (Settings not being saved)
30 May 2005
UK
I have just uninstalled Nero 8.1.1.0b and installed the new Nero 8.1.1.4, when i open Nero Burning ROM and go to File > Options > Audio > Options > Encoders > mp3/mp3PRO > Configure, i find that i can configure the mp3/mp3PRO plugin, but the settings that i enter are only saved until i exit Nero Burning ROM, when i close Nero Burning ROM or Nero Express after configuring the mp3/mp3PRO plugin then re-start Nero Burning ROM or Nero Express the settings i entered are lost.
Is anyone else having this issue with the mp3/mp3PRO plugin confiuration?
Thanks!
This is a screenshot of the options that are lost on exiting Nero.
I have now done some more testing, i have found that the configuration settings are only saved until i exit Nero Burning ROM or Nero Express at which point the settings are lost, this happens with all of the Nero plug-ins in the screenshot below, not just the mp3/mp3PRO plug-in, this doesn't accur whith Nero 8.1.1.0b, it only accurs with Nero 8.1.1.4, i also used the Nero 8 cleantool to uninstall the old Nero 8.1.1.0b before installing the new Nero 8.1.1.4.
