Nero 9 Essentials
14 Oct 2009
UK
I am not sure if this is in right forum :/
I need to burn some .avi and MPEG4 movies to some dvds so my mates daughter can watch them on her dvd player.
Will Nero 9 Essentials allow me to do this or do i need the full program.
Does anyone have any other suggestions to what programs i should use?
Thanks guys...
Needs to be in the software section mate, not hardware
If the Essentials package has Nero Vision, you can make your own DVD from Video Files, drag and drop them on, and it'll burn the DVD for you that will play on most players, takes a while though
Well if the DVD player supports avi (DivX) and MPEG4, then it should run. Else, u can try reauthoring the entire content in a format that is readable by any DVD player.
I dont think Nero essentials will be able to do it. Though you can try using Cyberlink DVD Suite or Ulead's both of which are good.
