Nero 9 is out
since nero 5, it's gone downhill, BIGTIME
imgburn
infra recorder
two burning tools that are better than Nero (for burning), and free
They want £39.99 to upgrade, and still as far as I can see in Vista 64 NO One click disc copy and disc image burning Gadget for the Windows Vista Sidebar but I am running the Demo so you may have to pay £39.99 to get that, I don't think so:mad:
I had a problem with an older version of clone CD it wouldn't let Vista recognise my DVD RW Drives.
so I might have to get the latest version.
I've only really use Nero to turn mp3's into a normal CD, can anyone recommend any free software that will do the same thing and work on XP + Vista?
thx
Don’t Bother with Nero 9
I saw no difference in the Nero 9 applications I use, so I uninstalled it, if you have Nero 8 save yourselves the download (370 MB) it’ s not worth it and as for paying £39.99 NO Way! :rolleyes::rolleyes::rolleyes:
I'm on Nero 8 just because the actual burning software is pretty decent and I'm used to it. But I won't be upgrading again until it fails to support new hardware or a new OS. But the amount of junk I had to prune out of the install... jeez. It's almost as if Ahead are in partnership with JML:
".. and now with Nero 10 and the JML toecam you can inspect your belly button without the need for a mirror. But that's not all, if you buy now you get a free fountain pen that can open a can of beans.."
Eh.. no thanks, think I'll pass on that.
