Nero burning problem...
20 Nov 2004
Stoke
Hi.
Im having trouble burning mp3s from my hard drive onto discs at the minute. Most of the track is fine, but for the first few seconds of each track it seems pretty jumpy and seems to repeat a second or two. I never used to have this problem, its only in the last week or so thats its happened.
I was using an NEC 3500 burner, but ive swapped that for an NEC 4551 now, but still get the same results.
Any ideas?
What OS are you using ?
I have XP and use the built in roxio
If i copy stuff to a disc i go to the folder ,Click Edit > select all , Then on the left hand side of the page at the top it says " copy to CD " .. click this it copys the files and a pop up appears saying you have files to copy to disc ... I click it and thay are ready to burn .
I then click on the left " copy filed to CD " done .
Make sure you have a disc in the drive thogh ;)
