Nero, Fusion or Krypt???
kfk
kfk
6 Dec 2008
Hi all,
I am looking to buy a gaming rig. My budget is approx £600 inc OS. I had a quick look and picked out these 3 systems. I am leaning towards the Nero as it has a lot of good reviews. Any advice? Which would be the best going forward? Any other system recomendations?
Thanks
Nero http://www.overclockers.co.uk/showproduct.php?prodid=FS-180-OK&groupid=43&catid=1445&subcat=
Fusion http://www.overclockers.co.uk/showproduct.php?prodid=FS-062-OE&groupid=43&catid=1445&subcat=
Krypt http://www.overclockers.co.uk/showproduct.php?prodid=FS-210-OK&tool=5
Nero has just been updated to include DirectX 11 graphics today.
I would dis-credit the Fusion, due to the upgrade to the Nero it will be phased out in the next few days as it no longer offers the same bang for buck levels compared with other systems in our range.
The Krypt is a great little system thanks to the quad core processor, however if you are only gaming then it is a close call between the Krypt and the Nero.
Personally I would ask yourself this:
Only gaming? Nero
Spend a fair bit of time in Windows doing work/image editing/DVD creation etc then the Krypt would edge it.
Comes down to value for money for what you want to do, all three systems are great and good sellers so you will be over the moon with any of them. The only choice is which one offers you the best value for money.
If you let me know what you are looking for in the system I can point you in the right direction of maybe another model in our range. :)
I am on MSN if you want to chat, [email protected] just tucking into a Chinese so will be online for a while. :D
Thanks for that, very informative. I am looking for the system mainly for gaming. Only other use really is for net surfing and some spreadsheets. I'm sure the Nero could handle excel OK:)
Well, I ordered the Nero today with 64 bit Windows 7. Looking forward to testing it out. I'm sure Ill be happy as my current rig is a dinosaur:)
