- 24 May 2004
Has anyone managed to get the NeroVision code examples to work using the current Nero 7 suite and the SDK? The SDK samples allow you to select an AVI and create a DVD/VCD/SVCD from it. Ive pretty much given up using the SDK as it appears to have been not updated for use with the current versions, but thought id see if anyones got them working for DVD transcoding and burning as per the NeroVision example.
The alternate solution in the end was to use open source software to achieve the same thing. Hail to Sourceforge! Crash and Burn
Nero!
Nero!
