Nero Vision (Nero 8)
9 Jan 2003
Cornwall
ok having a hell of a time with this, trying to burn a AVI I made ages ago (all working) onto a DVD with nero vision, worked before (3 weeks+) but its stopped working now! it encodes the DVD fine but then gets to the wrighting part and fails after about 20 seconds :(
heres the burn log (I think this is the important bit)
Code:
[20:15:13] DVDEngine  BEGIN: VTSTT_VOBS#1 - Write
[20:15:13] DVDEngine  ...RBP=0, count=1,073,739,776 bytes
[20:17:09] NeroVision Write error
[20:17:09] NeroVision E: SONY DVD RW AW-G170A
[20:17:12] DVDEngine  ...succeeded
[20:17:12] DVDEngine  END: VTSTT_VOBS#1 - Write
[20:17:12] NeroVision Burn process failed at 18x (24,930 KB/s)
[20:17:17] NeroVision Process information:
                     [Files named here .dlls etc]
[20:17:17] NeroVision Book type: 'Automatic'
[20:17:17] NeroVision 1K22-2867-0K95-61K4-5000-CKAC-****
[20:17:17] NeroVision Windows XP 5.1
[20:17:17] NeroVision IA32
[20:17:17] NeroVision WinAspi: -
[20:17:17] NeroVision NT-SPTI used
[20:17:17] NeroVision Nero API version: 8.0.3.0
[20:17:17] NeroVision Using interface version: 8.0.0.0
[20:17:17] NeroVision Installed in: C:\Program Files\Nero\Nero8\Nero Burning Rom\
[20:17:17] NeroVision Application: Nero\NeroVision
[20:17:17] NeroVision Internal Version: 8, 0, 3, 0
[20:17:17] NeroVision Recorder:             <SONY DVD RW AW-G170A>    Version: 1.71 - HA 1 TA 0 - 8.0.3.0
[20:17:17] NeroVision  Adapter driver:      <IDE>                     HA 1
[20:17:17] NeroVision  Drive buffer  :      2048kB
[20:17:17] NeroVision  Bus Type      :      default
[20:17:17] NeroVision === Scsi-Device-Map ===
[20:17:17] NeroVision DiskPeripheral       : ST3250620AS                      atapi Port 0 ID 0  DMA: On
[20:17:17] NeroVision DiskPeripheral       : ST3120026AS                      atapi Port 0 ID 1  DMA: On
[20:17:17] NeroVision CdRomPeripheral      : SONY    DVD RW AW-G170A 1.71     JRAID Port 4 ID 0  DMA: Off
[20:17:17] NeroVision CdRomPeripheral      : MagicISOVirtual DVD-ROM 1.0A    mcdbus Port 5 ID 0  DMA: Off
[20:17:17] NeroVision CdRomPeripheral      : SCSIVAX DVD/CD-ROM      2.7a  a0o7wxfr Port 6 ID 0  DMA: Off
[20:17:17] NeroVision === CDRom-Device-Map ===
[20:17:17] NeroVision SONY DVD RW AW-G170A       E:   CdRom0
[20:17:17] NeroVision SCSIVAX DVD/CD-ROM         F:   CdRom1
[20:17:17] NeroVision MagicISO Virtual DVD-ROM   G:   CdRom2
[20:17:17] NeroVision =======================
[20:17:17] NeroVision AutoRun : 0
[20:17:17] NeroVision Excluded drive IDs:
[20:17:17] NeroVision WriteBufferSize: 83886080 (0) Byte
[20:17:17] NeroVision BUFE           : 0
[20:17:17] NeroVision Physical memory     : 1023MB (1048044kB)
[20:17:17] NeroVision Free physical memory: 301MB (308720kB)
[20:17:17] NeroVision Memory in use       : 70 %
[20:17:17] NeroVision Uncached PFiles: 0x0
[20:17:17] NeroVision Use Inquiry    : 1
[20:17:17] NeroVision Global Bus Type: default (0)
[20:17:17] NeroVision Check supported media : Disabled (0)
[20:17:17] NeroVision 14.10.2007
[20:17:17] NeroVision NeroAPI
[20:17:17] NeroVision 20:15:13	#1 Phase 111 File APIProgress.cpp, Line 285
[20:17:17] NeroVision 	DVD-Video files sorted
[20:17:17] NeroVision 20:15:13	#2 Text 0 File SCSIPTICommands.cpp, Line 424
[20:17:17] NeroVision 	LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
[20:17:17] NeroVision 20:15:13	#3 ISO9660GEN -11 File Geniso.cpp, Line 3345
[20:17:17] NeroVision 	First writeable address = 0 (0x00000000)
[20:17:17] NeroVision 20:15:13	#4 ISO9660GEN -11 File Geniso.cpp, Line 3345
[20:17:17] NeroVision 20:15:13	#5 Text 0 File Burncd.cpp, Line 3520
[20:17:17] NeroVision 	Turn on Disc-At-Once, using DVD media
[20:17:17] NeroVision 20:15:13	#6 Text 0 File DlgWaitCD.cpp, Line 307
[20:17:17] NeroVision 	Last possible write address on media:  2298495 (510:46.45, 4489MB)
[20:17:17] NeroVision 	Last address to be written:            2251007 (500:13.32, 4396MB)
[20:17:17] NeroVision 20:15:13	#7 Text 0 File DlgWaitCD.cpp, Line 319
[20:17:17] NeroVision 	Write in overburning mode: NO (enabled: CD)
[20:17:17] NeroVision 20:15:13	#8 Text 0 File DlgWaitCD.cpp, Line 2972
[20:17:17] NeroVision 	Recorder: SONY DVD RW AW-G170A, Media type: DVD-R
[20:17:17] NeroVision 	 Disc Manufacturer: MCC 03 - RG20
[20:17:17] NeroVision 	 Disc Application Code: 64, Disc Physical Code: 193
[20:17:17] NeroVision 20:15:13	#9 Text 0 File DlgWaitCD.cpp, Line 493
[20:17:17] NeroVision 	>>> Protocol of DlgWaitCD activities: <<<
[20:17:17] NeroVision 	=========================================
[20:17:17] NeroVision 20:15:13	#10 Text 0 File ThreadedTransferInterface.cpp, Line 795
[20:17:17] NeroVision 	Setup items (after recorder preparation)
[20:17:17] NeroVision 	 0: TRM_DATA_MODE1 ()
[20:17:17] NeroVision 	    2 indices, index0 (150) not provided
[20:17:17] NeroVision 	    original disc pos #0 + 2251008 (2251008) = #2251008/500:13.33
[20:17:17] NeroVision 	    relocatable, disc pos for caching/writing not required/ required
[20:17:17] NeroVision 	    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2251008 blocks [E: SONY DVD RW AW-G170A]
[20:17:17] NeroVision 	--------------------------------------------------------------
[20:17:17] NeroVision 20:15:13	#11 Text 0 File ThreadedTransferInterface.cpp, Line 997
[20:17:17] NeroVision 	Prepare [E: SONY DVD RW AW-G170A] for write in CUE-sheet-DAO
[20:17:17] NeroVision 	DAO infos:
[20:17:17] NeroVision 	 MCN: ""
[20:17:17] NeroVision 	 TOCType: 0x00; Session Closed, disc fixated
[20:17:17] NeroVision 	 Tracks 1 to 1:                                  Idx 0         Idx 1      Next Trk
[20:17:17] NeroVision 	   1: TRM_DATA_MODE1, 2048/0x00, FilePos             0             0    4610064384, ISRC ""
[20:17:17] NeroVision 	DAO layout:
[20:17:17] NeroVision 	 ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
[20:17:17] NeroVision 	        0 |  lead-in |   0 |    0x41 |        0 |        0 | 0x00
[20:17:17] NeroVision 	        0 |        1 |   0 |    0x41 |        0 |        0 | 0x00
[20:17:17] NeroVision 	        0 |        1 |   1 |    0x41 |  2251008 |        0 | 0x00
[20:17:17] NeroVision 	  2251008 | lead-out |   1 |    0x41 |        0 |        0 | 0x00
[20:17:17] NeroVision 20:15:13	#12 Text 0 File SCSIPTICommands.cpp, Line 215
[20:17:17] NeroVision 	SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
[20:17:17] NeroVision 20:15:13	#13 Text 0 File Burncd.cpp, Line 4306
[20:17:17] NeroVision 	Caching options: cache CDRom or Network-No, small files-Yes (<32KB)
[20:17:17] NeroVision 20:15:13	#14 Phase 24 File APIProgress.cpp, Line 285
[20:17:17] NeroVision 	Caching of files started
[20:17:17] NeroVision 20:15:13	#15 Text 0 File Burncd.cpp, Line 4425
[20:17:17] NeroVision 	Cache writing successful.
[20:17:17] NeroVision 20:15:13	#16 Phase 25 File APIProgress.cpp, Line 285
[20:17:17] NeroVision 	Caching of files completed
[20:17:17] NeroVision 20:15:13	#17 Phase 36 File APIProgress.cpp, Line 285
[20:17:17] NeroVision 	Burn process started at 18x (24,930 KB/s)
[20:17:17] NeroVision 20:15:13	#18 Text 0 File ThreadedTransferInterface.cpp, Line 2723
[20:17:17] NeroVision 	Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
[20:17:17] NeroVision 20:15:13	#19 Text 0 File DVDR.cpp, Line 3227
[20:17:17] NeroVision 	Recording mode: Sequential Recording Mode
[20:17:17] NeroVision 20:15:13	#20 Text 0 File DVDR.cpp, Line 3383
[20:17:17] NeroVision 	Start write address at LBA 0
[20:17:17] NeroVision 	DVD high compatibility mode: Yes
[20:17:17] NeroVision 20:15:13	#21 Text 0 File Cdrdrv.cpp, Line 9918
[20:17:17] NeroVision 	---- Disc Structure: Physical Format Information (00h) ----
[20:17:17] NeroVision 	Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
[20:17:17] NeroVision 	 Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
[20:17:17] NeroVision 	 Disc Size: 120 mm,      Maximum Rate: <not specified> (F h)
[20:17:17] NeroVision 	 Number of Layers: 1,    Track Path: Parallel Track Path (PTP),  Layer Type: recordable
[20:17:17] NeroVision 	 Linear Density:         0,267 um/bit,  Track Density:  0,74 um/track
[20:17:17] NeroVision 	 Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
[20:17:17] NeroVision 	 End Sector Number in Layer 0:                 0 h (LBN: FFFD0000 h, 4193920 MB)
[20:17:17] NeroVision 	 Data in Burst Cutting Area (BCA) does not exist
[20:17:17] NeroVision 	  Revision number of maximum recording speed: 6.0
[20:17:17] NeroVision 	  Revision number of minimum recording speed: -
[20:17:17] NeroVision 	  Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
[20:17:17] NeroVision 	  Class: 0
[20:17:17] NeroVision 	  Start sector number of the current Border-Out: 2FE10 h
[20:17:17] NeroVision 	  Start sector number of the next Border-In:     2FFA0 h
[20:17:17] NeroVision 	 Media Specific [16..63]:
[20:17:17] NeroVision 	    00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00    .`...0@P...!....
[20:17:17] NeroVision 	    00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00    ..¦... .........
[20:17:17] NeroVision 	    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00    ................
[20:17:17] NeroVision 20:15:13	#22 Text 0 File ThreadedTransfer.cpp, Line 269
[20:17:17] NeroVision 	Pipe memory size 83836800
[20:17:17] NeroVision 20:15:15	#23 Text 0 File Cdrdrv.cpp, Line 1342
[20:17:17] NeroVision 	20:15:15.093 - ?????/?????A : Queue again later
[20:17:17] NeroVision 20:17:09	#24 SPTI -1135 File SCSIPassThrough.cpp, Line 181
[20:17:17] NeroVision 	CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
[20:17:17] NeroVision 	Sense Key:  0x03 (KEY_MEDIUM_ERROR)
[20:17:17] NeroVision 	Sense Code: 0x0C
[20:17:17] NeroVision 	Sense Qual: 0x00
[20:17:17] NeroVision 	CDB Data:   0x2A 00 00 06 00 40 00 00 20 00 00 00
[20:17:17] NeroVision 	Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 0C
[20:17:17] NeroVision 	Buffer x3118c540: Len x10000
[20:17:17] NeroVision 	0x00 00 01 BA 44 5D DD 55 1D E1 01 89 C3 F8 00 00
[20:17:17] NeroVision 	0x01 E0 07 EC 80 00 00 4D 88 A7 73 76 F4 F0 5E D1
[20:17:17] NeroVision 	0x7A A9 A0 C3 E9 CB B3 2E F7 55 34 26 12 F2 AF 33
[20:17:17] NeroVision 20:17:09	#25 CDR -1135 File Writer.cpp, Line 312
[20:17:17] NeroVision 	Write error
[20:17:17] NeroVision 	E: SONY DVD RW AW-G170A
[20:17:17] NeroVision 20:17:12	#26 Text 0 File DVDR.cpp, Line 3785
[20:17:17] NeroVision 	EndDAO: Last written address was 393279 (6003Fh)
[20:17:17] NeroVision 20:17:12	#27 Phase 38 File APIProgress.cpp, Line 285
[20:17:17] NeroVision 	Burn process failed at 18x (24,930 KB/s)
[20:17:17] NeroVision 20:17:12	#28 Text 0 File SCSIPTICommands.cpp, Line 261
[20:17:17] NeroVision 	SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
[20:17:17] NeroVision 20:17:17	#29 Text 0 File Cdrdrv.cpp, Line 11159
[20:17:17] NeroVision 	DriveLocker: UnLockVolume completed
[20:17:17] NeroVision 20:17:17	#30 Text 0 File SCSIPTICommands.cpp, Line 424
[20:17:17] NeroVision 	UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
[20:17:17] NeroVision Existing drivers:
[20:17:17] NeroVision Registry Keys:
[20:17:17] NeroVision HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
please help me! need to burn this for a display tomorrow!
files cut from prev post
Code:
[20:17:17] NeroVision Address     Version                  Module name
[20:17:17] NeroVision 0x00340000  5.0.0.6                  C:\Program Files\Nero\Nero8\Nero Vision\AMCDOM.dll
[20:17:17] NeroVision 0x00360000  5.0.0.6                  C:\Program Files\Nero\Nero8\Nero Vision\GCLib.dll
[20:17:17] NeroVision 0x00400000  5.0.0.6                  C:\Program Files\Nero\Nero8\Nero Vision\NeroVision.exe
[20:17:17] NeroVision 0x00510000  5.0.0.6                  C:\Program Files\Nero\Nero8\Nero Vision\AMCDocBase.dll
[20:17:17] NeroVision 0x00730000  5.0.0.6                  C:\Program Files\Nero\Nero8\Nero Vision\MMTools.dll
[20:17:17] NeroVision 0x007D0000  5.0.0.6                  C:\Program Files\Nero\Nero8\Nero Vision\Painter.dll
[20:17:17] NeroVision 0x00800000  5.0.0.6                  C:\Program Files\Nero\Nero8\Nero Vision\AMCUIBase.dll
[20:17:17] NeroVision 0x00AA0000  5.0.0.6                  C:\Program Files\Nero\Nero8\Nero Vision\AMCLib.dll
[20:17:17] NeroVision 0x00B00000  8.0.4.0                  C:\Program Files\Nero\Nero8\Nero Vision\NeroAPIGlueLayerUnicode.dll
[20:17:17] NeroVision 0x00B30000  5.0.0.6                  C:\Program Files\Nero\Nero8\Nero Vision\HDCC.dll
[20:17:17] NeroVision 0x01360000  0.0.0.0                  C:\Program Files\Ray Adams\ATI Tray Tools\raphook.dll
[20:17:17] NeroVision 0x01420000  0.0.0.0                  C:\Program Files\Xfire\xfire_toucan_28220.dll
[20:17:17] NeroVision 0x01700000  5.0.0.6                  C:\Program Files\Nero\Nero8\Nero Vision\DVDUI.dll
[20:17:17] NeroVision 0x01800000  6.0.5441.0               C:\WINDOWS\system32\Normaliz.dll
[20:17:17] NeroVision 0x01860000  7.0.74.0                 C:\WINDOWS\system32\ImagXpr7.dll
[20:17:17] NeroVision 0x01F30000  0.4.0.101                C:\Program Files\Common Files\Nero\Shared\NL3\AdvrCntr3.dll
[20:17:17] NeroVision 0x02600000  7.0.74.0                 C:\WINDOWS\system32\ImagX7.dll
[20:17:17] NeroVision 0x02AD0000  8.0.4.0                  C:\Program Files\Common Files\Nero\Shared\NL3\ShellManager3.dll
[20:17:17] NeroVision 0x02D30000  5.0.0.6                  C:\Program Files\Nero\Nero8\Nero Vision\ExpressDoc.dll
[20:17:17] NeroVision 0x02E30000  7.0.495.0                C:\WINDOWS\system32\ImagXR7.dll
[20:17:17] NeroVision 0x02F20000  2.0.0.9                  C:\Program Files\Common Files\Nero\Lib\Nero3DMenuEffects.dll
[20:17:17] NeroVision 0x03010000  7.10.3052.4              C:\Program Files\Common Files\Nero\Lib\msvcr71.dll
[20:17:17] NeroVision 0x03080000  1.2.3.0                  C:\Program Files\Common Files\Nero\Lib\zlib1.dll
[20:17:17] NeroVision 0x030A0000  1.9.0.0                  C:\Program Files\Common Files\Nero\Lib\iconv.dll
[20:17:17] NeroVision 0x03180000  5.99.3.1                 C:\Program Files\Common Files\Nero\Lib\cximage.dll
[20:17:17] NeroVision 0x03290000  1.3.0.0                  C:\Program Files\Common Files\Nero\Lib\lib3ds_dll.dll
[20:17:17] NeroVision 0x032B0000  9.12.589.0               C:\WINDOWS\system32\d3dx9_30.dll
[20:17:17] NeroVision 0x03510000  2.6.23.0                 C:\Program Files\Common Files\Nero\Lib\libxml2.dll
[20:17:17] NeroVision 0x03810000  8.0.4.0                  C:\Program Files\Common Files\Nero\NeroCaptureAPI\GCHW.dll
[20:17:17] NeroVision 0x04420000  5.0.0.6                  C:\Program Files\Nero\Nero8\Nero Vision\DVDDoc.dll
[20:17:17] NeroVision 0x04640000  5.0.0.6                  C:\Program Files\Nero\Nero8\Nero Vision\GCFX.dll
[20:17:17] NeroVision 0x04870000  8.0.3.0                  C:\Program Files\Nero\Nero8\Nero Burning Rom\NEROAPIENGINE.dll
[20:17:17] NeroVision 0x05660000  8.0.3.0                  C:\Program Files\Nero\Nero8\Nero Burning Rom\uCDCopy.dll
[20:17:17] NeroVision 0x056A0000  8.0.3.0                  C:\Program Files\Nero\Nero8\Nero Burning Rom\uNeroErr.dll
[20:17:17] NeroVision 0x056D0000  8.0.3.0                  C:\Program Files\Nero\Nero8\Nero Burning Rom\uNeRSDB.dll
[20:17:17] NeroVision 0x05710000  5.0.0.0                  C:\Program Files\Nero\Nero8\Nero Vision\NeroVideoFX.dll
[20:17:17] NeroVision 0x05950000  8.0.3.0                  C:\Program Files\Nero\Nero8\Nero Burning Rom\NEROAPIUNICODE.dll
[20:17:17] NeroVision 0x05B90000  1.0.0.21                 C:\Program Files\Common Files\Nero\Lib\DriveLocker.dll
[20:17:17] NeroVision 0x05E00000  5.0.0.0                  C:\Program Files\Nero\Nero8\Nero Vision\NeVideoFX.dll
[20:17:17] NeroVision 0x06FB0000  5.0.0.6                  C:\Program Files\Nero\Nero8\Nero Vision\ExpressUI.dll
[20:17:17] NeroVision 0x08CE0000  5.0.0.6                  C:\Program Files\Nero\Nero8\Nero Vision\DVDLib.dll
[20:17:17] NeroVision 0x08DA0000  3.0.4.0                  C:\Program Files\Common Files\Nero\Lib\NeroFileDialogCF.dll
[20:17:17] NeroVision 0x09390000  3.525.1117.0             C:\WINDOWS\system32\odbcint.dll
[20:17:17] NeroVision 0x094E0000  3.0.4.0                  C:\Program Files\Common Files\Nero\Lib\NeroFileDialog.dll
[20:17:17] NeroVision 0x09680000  8.60.0.0                 C:\Program Files\Common Files\Nero\Lib\BCGCBPRO860u80.dll
[20:17:17] NeroVision 0x09A30000  0.0.0.0                  C:\Program Files\Eset\nodshex.dll
[20:17:17] NeroVision 0x09AB0000  5.3.0.198                C:\Program Files\MagicISO\misosh.dll
[20:17:17] NeroVision 0x09B40000  3.0.4.0                  C:\Program Files\Common Files\Nero\Lib\NeroPreview.dll
[20:17:17] NeroVision 0x0A240000  11.0.8164.0              C:\Program Files\Common Files\Microsoft Shared\OFFICE11\MSOXMLMF.DLL
[20:17:17] NeroVision 0x0A570000  5.0.0.6                  C:\Program Files\Nero\Nero8\Nero Vision\GCCapture.ax
[20:17:17] NeroVision 0x0A5C0000  5.0.0.6                  C:\Program Files\Nero\Nero8\Nero Vision\GCFilter.ax
[20:17:17] NeroVision 0x0A690000  0.0.0.0                  C:\Program Files\Common Files\Teleca Shared\boost_log-vc71-mt-1_33.dll
[20:17:17] NeroVision 0x0A6C0000  1.0.13.61                C:\Program Files\Sony Ericsson\Mobile2\File Manager\FM.dll
[20:17:17] NeroVision 0x0A7C0000  7.10.3077.0              C:\WINDOWS\system32\MFC71ENU.DLL
[20:17:17] NeroVision 0x0A7D0000  0.0.0.0                  C:\Program Files\Sony Ericsson\Mobile2\File Manager\FMLang.dll
[20:17:17] NeroVision 0x0A7F0000  7.10.3077.0              C:\WINDOWS\system32\MFC71U.DLL
[20:17:17] NeroVision 0x0A900000  1.1.0.67                 C:\Program Files\Common Files\Teleca Shared\tlib_log.dll
[20:17:17] NeroVision 0x0AA30000  8.4.7.1034               C:\Program Files\Logitech\Video\Namespc2.dll
[20:17:17] NeroVision 0x0AA70000  8.4.7.1034               C:\Program Files\Logitech\Video\AlbuDBps.dll
[20:17:17] NeroVision 0x0AA80000  5.2.5721.5145            C:\WINDOWS\system32\Audiodev.dll
[20:17:17] NeroVision 0x0ACD0000  3.0.4.0                  C:\Program Files\Common Files\Nero\Lib\MediaLibraryNSE.dll
[20:17:17] NeroVision 0x0B1B0000  3.0.4.0                  C:\Program Files\Common Files\Nero\Lib\NMDataServices.dll
[20:17:17] NeroVision 0x0B770000  0.0.0.0                  C:\Program Files\Haali\MatroskaSplitter\mmfinfo.dll
[20:17:17] NeroVision 0x0B780000  0.0.0.0                  C:\Program Files\Haali\MatroskaSplitter\mkunicode.dll
[20:17:17] NeroVision 0x0B790000  4.42.0.0                 C:\Program Files\7-Zip\7-zip.dll
[20:17:17] NeroVision 0x0B7E0000  1.6.338.23               C:\Program Files\Haali\MatroskaSplitter\splitter.ax
[20:17:17] NeroVision 0x0B860000  0.0.0.0                  C:\Program Files\Haali\MatroskaSplitter\mkzlib.dll
[20:17:17] NeroVision 0x0B880000  3.0.3.0                  C:\Program Files\Nero\Nero8\Nero BackItUp\NBShell.dll
[20:17:17] NeroVision 0x0B8C0000  0.0.0.0                  C:\Program Files\Haali\MatroskaSplitter\mkx.dll
[20:17:17] NeroVision 0x0B8E0000  0.0.0.0                  C:\Program Files\Haali\MatroskaSplitter\avi.dll
[20:17:17] NeroVision 0x0B920000  0.0.0.0                  C:\Program Files\WinRAR\rarext.dll
[20:17:17] NeroVision 0x0B950000  7.0.7.0                  C:\Program Files\Adobe\Acrobat 7.0\Distillr\ADIST32.dll
[20:17:17] NeroVision 0x0B9E0000  3.0.1.0                  C:\Program Files\Nero\Nero8\Nero CoverDesigner\CoverEdExtension.dll
[20:17:17] NeroVision 0x0BBF0000  1.3.9.2                  C:\Program Files\Common Files\Nero\DSFilter\NeMP4Splitter.ax
[20:17:17] NeroVision 0x0BD30000  7.0.7.0                  C:\Program Files\Adobe\Acrobat 7.0\Acrobat Elements\ContextMenu.dll
[20:17:17] NeroVision 0x0BE10000  1.0.0.1                  C:\Program Files\Pulse\Dolphin.dll
[20:17:17] NeroVision 0x0BEC0000  1.1.0.0                  C:\Program Files\Common Files\Nero\DSFilter\NeVideoAnalyzer.ax
[20:17:17] NeroVision 0x0C6E0000  1.1.0.2                  C:\Program Files\Common Files\Nero\DSFilter\NeColorspace.ax
[20:17:17] NeroVision 0x0C720000  2.4.8.2                  C:\Program Files\Common Files\Nero\DSFilter\NeAudio2.ax
[20:17:17] NeroVision 0x0CB90000  3.2.3.3                  C:\Program Files\Common Files\Nero\DSFilter\NeVideo.ax
[20:17:17] NeroVision 0x0CDF0000  1.2.0.1                  C:\Program Files\Common Files\Nero\DSFilter\NeFramerate.ax
[20:17:17] NeroVision 0x0CE20000  1.1.0.1                  C:\Program Files\Common Files\Nero\DSFilter\NeroVideoProc.ax
[20:17:17] NeroVision 0x0DB70000  1.6.1.4                  C:\Program Files\Common Files\Nero\DSFilter\NeResize.ax
[20:17:17] NeroVision 0x0E920000  2.0.1.3                  C:\Program Files\Common Files\Nero\DSFilter\NeSoundProc.ax
[20:17:17] NeroVision 0x0EBA0000  8.0.0.0                  C:\Program Files\Common Files\Nero\Lib\NeroCBUI.dll
[20:17:17] NeroVision 0x10000000  5.0.0.6                  C:\Program Files\Nero\Nero8\Nero Vision\GCCore.dll
[20:17:17] NeroVision 0x10930000  5.2.5721.5145            C:\WINDOWS\system32\PortableDeviceApi.dll
[20:17:17] NeroVision 0x11C70000  11.0.5721.5145           C:\WINDOWS\system32\WMASF.DLL
[20:17:17] NeroVision 0x14070000  11.0.5721.5145           C:\WINDOWS\system32\wmpshell.dll
[20:17:17] NeroVision 0x15000000  8.0.3.0                  C:\Program Files\Nero\Nero8\Nero Burning Rom\uIMAGE.DLL
[20:17:17] NeroVision 0x15110000  11.0.5721.5145           C:\WINDOWS\system32\WMVCore.DLL
[20:17:17] NeroVision 0x16210000  5.2.5721.5145            C:\WINDOWS\system32\wpdshext.dll
[20:17:17] NeroVision 0x18000000  8.0.3.0                  C:\Program Files\Nero\Nero8\Nero Burning Rom\uISOFS.dll
[20:17:17] NeroVision 0x18800000  2.7.1.0                  C:\Program Files\UltraMon\RTSUltraMonHook.dll
[20:17:17] NeroVision 0x18900000  0.0.0.0                  C:\Program Files\UltraMon\Resources\en\RTSUltraMonHookRes.dll
[20:17:17] NeroVision 0x19000000  8.0.3.0                  C:\Program Files\Nero\Nero8\Nero Burning Rom\uMMC.DLL
[20:17:17] NeroVision 0x20000000  5.1.2600.2180            C:\WINDOWS\system32\xpsp2res.dll
[20:17:17] NeroVision 0x22000000  8.0.3.0                  C:\Program Files\Nero\Nero8\Nero Burning Rom\unewtrf.dll
[20:17:17] NeroVision 0x42990000  7.0.6000.16544           C:\WINDOWS\system32\iertutil.dll
[20:17:17] NeroVision 0x42C10000  7.0.6000.16544           C:\WINDOWS\system32\WININET.dll
[20:17:17] NeroVision 0x42CF0000  7.0.6000.16544           C:\WINDOWS\system32\urlmon.dll
[20:17:17] NeroVision 0x42EF0000  7.0.6000.16544           C:\WINDOWS\system32\ieframe.dll
[20:17:17] NeroVision 0x4D4F0000  5.1.2600.2180            C:\WINDOWS\system32\WINHTTP.dll
[20:17:17] NeroVision 0x4EC50000  5.1.3102.2180            C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.2600.2180_x-ww_522f9f82\gdiplus.dll
[20:17:17] NeroVision 0x4FDD0000  5.3.2600.2180            C:\WINDOWS\system32\D3D9.DLL
[20:17:17] NeroVision 0x58390000  1.0.0.0                  C:\WINDOWS\system32\l3codeca.acm
[20:17:17] NeroVision 0x593F0000  5.1.2600.2180            C:\WINDOWS\system32\wiashext.dll
[20:17:17] NeroVision 0x5A500000  8.1.178.0                C:\Program Files\MSN Messenger\fsshext.8.1.0178.00.dll
[20:17:17] NeroVision 0x5AD70000  6.0.2900.2180            C:\WINDOWS\system32\uxtheme.dll
[20:17:17] NeroVision 0x5B860000  5.1.2600.2976            C:\WINDOWS\system32\NETAPI32.dll
[20:17:17] NeroVision 0x5CAD0000  6.0.2900.2180            C:\WINDOWS\system32\shmedia.dll
[20:17:17] NeroVision 0x5D090000  6.0.2900.2982            C:\WINDOWS\system32\COMCTL32.dll
[20:17:17] NeroVision 0x5D360000  8.0.50727.762            C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303\MFC80ENU.DLL
[20:17:17] NeroVision 0x5ED00000  5.1.2600.2180            C:\WINDOWS\system32\OPENGL32.dll
[20:17:17] NeroVision 0x605D0000  5.1.2600.2180            C:\WINDOWS\system32\mslbui.dll
[20:17:17] NeroVision 0x60CA0000  6.5.2600.2180            C:\WINDOWS\system32\qedit.dll
[20:17:17] NeroVision 0x68B20000  5.1.2600.2180            C:\WINDOWS\system32\GLU32.dll
[20:17:17] NeroVision 0x69450000  5.1.2600.2180            C:\WINDOWS\system32\FAULTREP.DLL
[20:17:17] NeroVision 0x69B10000  4.20.9848.0              c:\WINDOWS\system32\msxml4.dll
[20:17:17] NeroVision 0x6D990000  5.3.2600.2180            C:\WINDOWS\system32\d3d8thk.dll
[20:17:17] NeroVision 0x71AA0000  5.1.2600.2180            C:\WINDOWS\system32\WS2HELP.dll
[20:17:17] NeroVision 0x71AB0000  5.1.2600.2180            C:\WINDOWS\system32\WS2_32.dll
[20:17:17] NeroVision 0x71AD0000  5.1.2600.2180            C:\WINDOWS\system32\WSOCK32.dll
[20:17:17] NeroVision 0x71B20000  5.1.2600.2180            C:\WINDOWS\system32\MPR.dll
[20:17:17] NeroVision 0x71BF0000  5.1.2600.2180            C:\WINDOWS\system32\SAMLIB.dll
[20:17:17] NeroVision 0x71C10000  5.1.2600.2180            C:\WINDOWS\System32\ntlanman.dll
[20:17:17] NeroVision 0x71C80000  5.1.2600.2180            C:\WINDOWS\System32\NETRAP.dll
[20:17:17] NeroVision 0x71C90000  5.1.2600.2180            C:\WINDOWS\System32\NETUI1.dll
[20:17:17] NeroVision 0x71CD0000  5.1.2600.2180            C:\WINDOWS\System32\NETUI0.dll
[20:17:17] NeroVision 0x72D10000  5.1.2600.0               C:\WINDOWS\system32\msacm32.drv
[20:17:17] NeroVision 0x72D20000  5.1.2600.2180            C:\WINDOWS\system32\wdmaud.drv
[20:17:17] NeroVision 0x73000000  5.1.2600.2180            C:\WINDOWS\system32\WINSPOOL.DRV
[20:17:17] NeroVision 0x732E0000  5.1.2600.0               C:\WINDOWS\system32\RICHED32.DLL
[20:17:17] NeroVision 0x736B0000  6.5.2600.2180            C:\WINDOWS\system32\msdmo.dll
[20:17:17] NeroVision 0x73760000  5.3.2600.2180            C:\WINDOWS\system32\DDRAW.dll
[20:17:17] NeroVision 0x73940000  5.3.2600.2180            C:\WINDOWS\system32\D3DIM700.DLL
[20:17:17] NeroVision 0x73B50000  5.1.2600.2180            C:\WINDOWS\system32\AVIFIL32.dll
[20:17:17] NeroVision 0x73BA0000  5.1.2600.2180            C:\WINDOWS\system32\sti.dll
[20:17:17] NeroVision 0x73BC0000  5.1.2600.2180            C:\WINDOWS\system32\DCIMAN32.dll
[20:17:17] NeroVision 0x73D70000  6.0.2900.2180            C:\WINDOWS\system32\shgina.dll
[20:17:17] NeroVision 0x73DD0000  6.2.4.0                  C:\WINDOWS\system32\MFC42.DLL
[20:17:17] NeroVision 0x73EE0000  5.3.2600.2180            C:\WINDOWS\system32\KsUser.dll
[20:17:17] NeroVision 0x73F10000  5.3.2600.2180            C:\WINDOWS\system32\dsound.dll
[20:17:17] NeroVision 0x74320000  3.525.1117.0             C:\WINDOWS\system32\ODBC32.dll
[20:17:17] NeroVision 0x74720000  5.1.2600.2180            C:\WINDOWS\system32\MSCTF.dll
[20:17:17] NeroVision 0x74810000  6.5.2600.2749            C:\WINDOWS\system32\QUARTZ.dll
[20:17:17] NeroVision 0x74980000  8.90.1101.0              C:\WINDOWS\system32\msxml3.dll
[20:17:17] NeroVision 0x74AD0000  6.0.2900.2180            C:\WINDOWS\system32\POWRPROF.dll
[20:17:17] NeroVision 0x74AE0000  5.1.2600.2180            C:\WINDOWS\system32\CFGMGR32.dll
[20:17:17] NeroVision 0x74C80000  5.1.2600.0               C:\WINDOWS\system32\OLEACC.dll
[20:17:17] NeroVision 0x74E30000  5.0.0.0                  C:\WINDOWS\system32\RICHED20.dll
[20:17:17] NeroVision 0x74ED0000  5.1.2600.2180            C:\WINDOWS\system32\wbem\wbemsvc.dll
[20:17:17] NeroVision 0x74EF0000  5.1.2600.2180            C:\WINDOWS\system32\wbem\wbemprox.dll
[20:17:17] NeroVision 0x75290000  5.1.2600.2180            C:\WINDOWS\system32\wbem\wbemcomn.dll
[20:17:17] NeroVision 0x754D0000  5.131.2600.2180          C:\WINDOWS\system32\CRYPTUI.dll
[20:17:17] NeroVision 0x755C0000  5.1.2600.2180            C:\WINDOWS\system32\msctfime.ime
[20:17:17] NeroVision 0x75690000  5.1.2600.2180            C:\WINDOWS\system32\wbem\fastprox.dll
[20:17:17] NeroVision 0x757F0000  6.5.2600.2180            C:\WINDOWS\system32\qcap.dll
[20:17:17] NeroVision 0x75970000  5.1.2600.2180            C:\WINDOWS\system32\MSGINA.dll
[20:17:17] NeroVision 0x75A70000  5.1.2600.2180            C:\WINDOWS\system32\MSVFW32.dll
[20:17:17] NeroVision 0x75E90000  5.1.2600.3019            C:\WINDOWS\system32\SXS.DLL
[20:17:17] NeroVision 0x75F40000  6.5.2600.2180            C:\WINDOWS\system32\devenum.dll
[20:17:17] NeroVision 0x75F60000  5.1.2600.2180            C:\WINDOWS\System32\drprov.dll
[20:17:17] NeroVision 0x75F70000  5.1.2600.2180            C:\WINDOWS\System32\davclnt.dll
[20:17:17] NeroVision 0x75F80000  6.0.2900.2995            C:\WINDOWS\system32\browseui.dll
[20:17:17] NeroVision 0x76080000  6.2.3104.0               C:\WINDOWS\system32\MSVCP60.dll
[20:17:17] NeroVision 0x76360000  5.1.2600.2180            C:\WINDOWS\system32\WINSTA.dll
[20:17:17] NeroVision 0x76380000  5.1.2600.2180            C:\WINDOWS\system32\MSIMG32.dll
[20:17:17] NeroVision 0x76390000  5.1.2600.2180            C:\WINDOWS\system32\IMM32.DLL
[20:17:17] NeroVision 0x763B0000  6.0.2900.2180            C:\WINDOWS\system32\COMDLG32.dll
[20:17:17] NeroVision 0x76600000  5.1.2600.2180            C:\WINDOWS\System32\CSCDLL.dll
[20:17:17] NeroVision 0x767A0000  5.1.2600.2180            C:\WINDOWS\system32\NTDSAPI.dll
[20:17:17] NeroVision 0x76980000  5.1.2600.2751            C:\WINDOWS\system32\LINKINFO.dll
[20:17:17] NeroVision 0x76990000  5.1.2600.2180            C:\WINDOWS\system32\ntshrui.dll
[20:17:17] NeroVision 0x769C0000  5.1.2600.2180            C:\WINDOWS\system32\USERENV.dll
[20:17:17] NeroVision 0x76B20000  6.5.0.2284               C:\WINDOWS\system32\ATL.DLL
[20:17:17] NeroVision 0x76B40000  5.1.2600.2180            C:\WINDOWS\system32\WINMM.dll
[20:17:17] NeroVision 0x76BF0000  5.1.2600.2180            C:\WINDOWS\system32\PSAPI.DLL
[20:17:17] NeroVision 0x76C30000  5.131.2600.2180          C:\WINDOWS\system32\WINTRUST.dll
[20:17:17] NeroVision 0x76C90000  5.1.2600.2180            C:\WINDOWS\system32\IMAGEHLP.dll
[20:17:17] NeroVision 0x76D60000  5.1.2600.2912            C:\WINDOWS\system32\iphlpapi.dll
[20:17:17] NeroVision 0x76F20000  5.1.2600.2938            C:\WINDOWS\system32\DNSAPI.dll
[20:17:17] NeroVision 0x76F50000  5.1.2600.2180            C:\WINDOWS\system32\WTSAPI32.dll
[20:17:17] NeroVision 0x76F60000  5.1.2600.2180            C:\WINDOWS\system32\WLDAP32.dll
[20:17:17] NeroVision 0x76FD0000  3.0.0.4414               C:\WINDOWS\system32\CLBCATQ.DLL
[20:17:17] NeroVision 0x77050000  3.0.0.4414               C:\WINDOWS\system32\COMRes.dll
[20:17:17] NeroVision 0x77120000  5.1.2600.3139            C:\WINDOWS\system32\OLEAUT32.dll
[20:17:17] NeroVision 0x773D0000  6.0.2900.2982            C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2982_x-ww_ac3f9c03\comctl32.dll
[20:17:17] NeroVision 0x774E0000  5.1.2600.2726            C:\WINDOWS\system32\ole32.dll
[20:17:17] NeroVision 0x77760000  6.0.2900.2987            C:\WINDOWS\system32\shdocvw.dll
[20:17:17] NeroVision 0x77920000  5.1.2600.2180            C:\WINDOWS\system32\SETUPAPI.dll
[20:17:17] NeroVision 0x77A20000  5.1.2600.2180            C:\WINDOWS\System32\cscui.dll
[20:17:17] NeroVision 0x77A80000  5.131.2600.2180          C:\WINDOWS\system32\CRYPT32.dll
[20:17:17] NeroVision 0x77B20000  5.1.2600.2180            C:\WINDOWS\system32\MSASN1.dll
[20:17:17] NeroVision 0x77B40000  5.1.2600.2180            C:\WINDOWS\system32\appHelp.dll
[20:17:17] NeroVision 0x77BD0000  5.1.2600.2180            C:\WINDOWS\system32\midimap.dll
[20:17:17] NeroVision 0x77BE0000  5.1.2600.2180            C:\WINDOWS\system32\MSACM32.dll
[20:17:17] NeroVision 0x77C00000  5.1.2600.2180            C:\WINDOWS\system32\VERSION.dll
[20:17:17] NeroVision 0x77C10000  6.1.8638.2180            C:\WINDOWS\system32\msvcrt.dll
[20:17:17] NeroVision 0x77DD0000  5.1.2600.2180            C:\WINDOWS\system32\ADVAPI32.dll
[20:17:17] NeroVision 0x77E70000  5.1.2600.3173            C:\WINDOWS\system32\RPCRT4.dll
[20:17:17] NeroVision 0x77F10000  5.1.2600.3159            C:\WINDOWS\system32\GDI32.dll
[20:17:17] NeroVision 0x77F60000  6.0.2900.2995            C:\WINDOWS\system32\SHLWAPI.dll
[20:17:17] NeroVision 0x77FE0000  5.1.2600.2180            C:\WINDOWS\system32\Secur32.dll
[20:17:17] NeroVision 0x78130000  8.0.50727.762            C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700\MSVCR80.dll
[20:17:17] NeroVision 0x781D0000  8.0.50727.762            C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_3bf8fa05\MFC80.DLL
[20:17:17] NeroVision 0x782E0000  8.0.50727.762            C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_3bf8fa05\MFC80U.DLL
[20:17:17] NeroVision 0x7C140000  7.10.3077.0              C:\WINDOWS\system32\MFC71.DLL
[20:17:17] NeroVision 0x7C340000  7.10.3052.4              C:\WINDOWS\system32\MSVCR71.DLL
[20:17:17] NeroVision 0x7C3A0000  7.10.3077.0              C:\WINDOWS\system32\MSVCP71.dll
[20:17:17] NeroVision 0x7C420000  8.0.50727.762            C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700\MSVCP80.dll
[20:17:17] NeroVision 0x7C800000  5.1.2600.3119            C:\WINDOWS\system32\kernel32.dll
[20:17:17] NeroVision 0x7C900000  5.1.2600.2180            C:\WINDOWS\system32\ntdll.dll
[20:17:17] NeroVision 0x7C9C0000  6.0.2900.3051            C:\WINDOWS\system32\SHELL32.dll
[20:17:17] NeroVision 0x7D1E0000  3.1.4000.4039            C:\WINDOWS\system32\msi.dll
[20:17:17] NeroVision 0x7E410000  5.1.2600.3099            C:\WINDOWS\system32\USER32.dll
I set it to 4 in the options! gah this is a problem I had with burning rom, it would try at 18 or whatever unless I set it to 4x manualy
I don't get why vision is trying to burn at 18 even tho I've set it to 4??!?!!
