Nero with vista 64bit
I`m using nero 8
when i start up nero i get an error message
Unable to create XMLparser instance.
Please reinstall Microsoft XML Core Services (MSXML) 4.0 SP2 or higher.
I use winavi 8 to covert avi to mpeg, then use dvd shrink so i can put to a dvd, with using nero as the burning tool.
Cheers.
Ok I have re-installed the vista 64 os
I`ve updated to sp1
http://www.microsoft.com/downloads/...0e-4275-482d-9524-de850c4dd91c&displaylang=en
I use nero 8
winavi 8
Dvd Shrink 3.2
All of them work ok, so I copied an avi file to a dvd-r disc and everything works as in xp pro 32bit os.
So when i put the disc in a dvd player, it doesn`t want to play:confused:
So i try again, but then i make the 3 programes compatible with xp pro sp2..and still the same:mad:
Any help would be great....Thanks
