NESS D8XD alarm system deault ip address confusion
5 Dec 2005
Dear folks
NESS D8XD alarm system installed on a business for my friend and a technician who installed it he said he didn't change the alarm system default ip address.
http://nesscorporation.com/ness-security/ness-control-panels/home-security/k-6308.html
Default ip is 192.168.0.251 ,,,as per the advise of their National Customer Service Centre,,,I called them and spoke with them
The confusing part I can ping this ip address (192.168.0.251) but it is neither in the list of the attached wired devices nor in the list of attached wireless devices (any way NESS is a wired box)
Snapshot below is for the attached wired devices :
https://imgur.com/a/GPvm98R
And the ping result is below :
Code:
C:\WINDOWS\System32>ping 192.168.0.251
Pinging 192.168.0.251 with 32 bytes of data:
Reply from 192.168.0.251: bytes=32 time=6ms TTL=64
Reply from 192.168.0.251: bytes=32 time=2ms TTL=64
Reply from 192.168.0.251: bytes=32 time=3ms TTL=64
Reply from 192.168.0.251: bytes=32 time=4ms TTL=64
Ping statistics for 192.168.0.251:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 2ms, Maximum = 6ms, Average = 3ms
Confusion how can I ping the ip address and it is not listed in my router table ???
Thanks
Open cmd prompt and do:
Code:
arp -a | findstr .251
And see what mac address it is. Then look up the address and see what vendor it is.
Stupid question, but did you try scrolling down?
