Hi all
Just had a chat with a Nest installer who didn't seem too clued up on dual zone installs (so I won't be using him lol) but I thought I would check with you lot to make sure what I have isn't something "out of the ordinary".
New build property as of 2018. Ideal Logic C35 boiler with 2 zones. One thermostat in the lounge and one in the master bedroom. I had assumed you would just buy 2 x Nest Learning Thermostats and you would install both Heat Links, one to each zone. Yay/nay?
My boiler is OpenTherm compatible with the installation of a £7 harness. Is this something I should get and use with the Nest system or does it not really matter or... ?
Thanks in advance
Thanks in advance
