Hi all,
So I hope some of you might have already done this. I have been taking a serious look at the nest thermostats to replace my horstmann channel plus h37xl thermostat, which has got 2 'satellite' thermostats wired to it for controlling upstairs and downstairs zones for heat (located in the dining room downstairs and the main bedroom upstairs), and it also controls hot water only on an oil fired condenser boiler, which sits outside.
From reading about nest, I understand that I will need 2 heatlinks and 2 nest thermostats to replace each zone thermostat, but what happens the existing horstmann unit? Does it stay in place or does something else replace it? Does it just be set to always on and the nest thermostats do their job?
Thanks in advance for any advice.
