Nested Functions
  • Thread starter Thread starter Bar
  • Start date Start date
Bar
Bar
9 Apr 2004
Brain has gone completely blank this morning.
I am trying to create a nested function but keep getting a #VALUE! error and I cannot work out what I have done wrong.
the formula so far looks like this
=IF(SUM(G3*H3)>9,"High",AND(IF(SUM(H3*G3)>5<9,"Medium"),AND(IF(SUM(H3*G3)<5,"Low"))))
G3 and H3 return a value looked up from an array - this part works.
Unfortunately when I try the above formula it works if the value is greater than 9 but I cannot get it to work with over values.
What obvious thing am I doing wrong?
Shouldn't it be 'OR', not 'AND'? Been a while since I did this sort of thing...
Code:
=IF(
     SUM(G3*H3)>9,
     "High",
     AND(
           IF(
              SUM(H3*G3)>5<9,
              "Medium"
      AND(
            IF(
               SUM(H3*G3)<5,
               "Low"
Edit: That's just to lay it out more easily, I've no idea about Excel :p
You don't nest with multiple parentheses, try this;
=IF(SUM(G3*H3)>9,"High",IF(AND((SUM(H3*G3)>5),(SUM(H3*G3)<9)),"Medium",IF(SUM(H3*G3)<5,"Low")))
edit: forgot about your middle condition.
Spot on Bam0 - knew it would be a stupid mistake.
Now for some reason it won't accept the >5<9 parameter.
Any thoughts?
Any thoughts?
>5 AND <9? (can't remember if that's what you actually put in excel, been a while since I used it)
I think it should be something like this...
=IF(SUM(G3*H3)<9,IF(SUM(G3*H3)>5,"Medium","Low"),"High")
"Low" is displayed if it is less than 9 and less than 5, "Medium" if it is less than 9 but greater than 5, and "High" if it is greater than 9.
Havent got Excel on this PC so I might have missed something out or made a mess of the brackets
