nested router help
  • Thread starter Thread starter ryu
  • Start date Start date
ryu
ryu
25 Oct 2002
hi all, i require some help/suggestions for setting up a network with 2 routers.
well its actually setup and working fine but not sure its done properly
ive got
adsl > dgn2200 > linksys wireless router(but wireless turned off and used solely as a hub for 3x lan pcs and networked printer)
i wanted wireless and wired(lan) to be independant and not be able to talk to eachother (securing the lan but still having inet access)
the dgn is on 192.168.0.x
the linksys is on 192.168.1.x and a different subnet to the dgn
theyve both got dhcp and nat on, is this right or not?
and also the dgn2200 has the \\readyshare usb feature. devices connected to the dgn can access it fine, but anything on the linksys appear not to be in reach is there anyway to achieve the wired/wireless independance but both being able to access the usb port on the dgn?
thanks in advance if i havent lost you.
