Permabanned
- 28 Dec 2009
- london
My colleague and myself have been setting up a dual controller 2240 this past week with three esxi hp dl385. We also have two cisco 2960 for use as storage only switches.
We have set up the ISCSi and tested redundancy with turning off a switch and also with doing a controller failover and that works ok. We are having an issue with NFS though.
The two switches are not connected to each other and we were not sure on whether we could use multi or single link configuration.
We have created a vif with two interfaces per controller then each interface goes in to one switch. It works ok, but we are getting "Link Monitoring Logic Failed " on the nfs interfaces on the cli. When we do a controller failover the nfs does not failover as would be expected. Someone we know suggested that they thought the switches would have to be connected to each other. Currently the interface is on a single mode configuration, as opposed to multi or lacp. We have not tried multi yet and don't think lacp will work because of two switches being in use.
Are we doing it all wrong? Might be difficult to help without seeing the netapp configuration. But if you have any advice on using this sort of configuration ill appreciate it.
edit: ok the nfs issue is resolved. It was that the two switches needed connecting together because the netapp intefaces need to be able to communicate with each other and if they can't then it causes the issues we were having.
Another question I have is it recommended to put nfs and iscsi on to their own vlans, even if there is isolated storage switches and each protocol has its own interfaces ?
