I installed Netbeans via adept over the weekend. I have JDK1.6 installed already.
When i run Netbeans it tells me that I need to install the JDK or run netbeans with the --jdkhome parameter.
I'm running KDE4 and would like to use the shortcut on favourites to launch Netbeans. Is there a way to modify this shortcut so that it passes the parameter?
Thanks
Russ
Thanks
Russ
