netbook (bluetooth and easily upgradable)
4 May 2006
Looking at buying a netbook just for word processing and casual browsing of the web, although if I can watch some movies too its a definite bonus!. I would however like to use my bluetooth mouth and would rather have it internally rather than using a dongle, as well as being reasonably easy to upgrade the ram.
Are there many options available, preferably for under £250 although i can stretch a bit.
Thanks,
Rich
Eeepc 901 is perfect, but a little out of your budget. If you could stretch its the best netbook on the market and runs most programs fine on windows xp
I have the MSI Wind, has bluetooth and ive upgraded it to 2gb RAM. There was a article in Custom PC the other month showing you how to upgrade various things on the Wind. If you want the same netbook for cheaper then look at the rebadged Wind by Advent. You can go have a look at it in the Purple Shirt store. 10" screen too which is better obv for watching movies.
