Netbook/Small Laptop
14 Feb 2004
Peoples Republic of Histonia, Cambridge
any adive on what's good at the moment.
Requirements are.
Max Budget: ~£350
Spec
Dual Core
3GB Ram
~12" Screen
Solid Keyboard and Trackpad
Decent Battery Life
Weight is an important factor as it's to be carried around a lot.
How about an Acer 8371 - see this thread for details......
Spec is :
Intel® ULV Core 2 Duo (ULV SU9400, 3 MB L2 cache, 1.4GHz, 800MHz FSB)
13.3" (Acer CineCrystal, 1366x768 HD, High Brightness, LED Backlit)
Win Vista Business
4GB (DDR3 1066MHZ)
320GB HDD
ATI Mobility Radeon HD 4330 with 512MB Dedicated RAM
5-in-1 card reader (SD//MS/MS-Pro/MMC/xD-Picture card™)
3x USB 2.0 ports
Kensington lock slot
8 Hrs+ Battery Life
1.6Kg
Comes in @ £350
Spec is :
Win Vista Business
4GB (DDR3 1066MHZ)
320GB HDD
3x USB 2.0 ports
8 Hrs+ Battery Life
1.6Kg
Comes in @ £350
Cool, looks like what I'm after :)
I can only find the 3GB version with integrated graphics for £330. The 4GB one with dedicated graphics seems to be around £380+. Does that sound right or should I keep looking?
Sounds about right. The price fluctuates with the demand and stocks on a weekly basis. Some got the HD 4330 version for £350, but I think £380 is still a fair price for the unit. £380 would be the higher tier, you may find it for cheaper once they get back in stock (or not, Christmas coming and all).
