Hi
First post, as per the title, my Asus x101h which is just over a year old has suddenly developed a fault in which it will not turn on, or resume from sleep with the battery in, on battery power or ac. If the battery is taken out, it turns on, and the battery can then be put back and the netbook works perfectly. The battery shows it being charged and charges fully, lasting the normal time once turned on.
Is the battery dead, or could it be another problem?
Thanks
Richard
Thanks
Richard
