Netgear DG834: difference between v1,2 and 3 versions?
4 Feb 2004
Écosse
Whats the difference between the v1, v2 and v3 DG834?
Is it just the firmware version of the router?.
Can an earlier version be updated to a later revision?.
Thanks.
Not sure what the differences are but yes the firmware can be updated, just go into the router config and select firmware upgrade:)
v1 and v2 are the same - just a cosmetic case change.
v3 is different as it was a hardware update as well as firmware. Only v1 and v2 use the same firmware, 3 is completely different. As to the exact hardware changes, I cannot help too much there, sorry.
