netgear dg834 upnp problems with azureus
13 Jul 2005
Devon
if im using azureus sometimes i get the yellow face and when i go into upnp in the router there is nothing in the UPnP Portmap Table,even though turn-on upnp is ticked.
i have to untick then press apply, then tick then apply then it works,sometimes it does work without me unticking but most of the time i have to untick then tick
ive tried different firmwares still acts the same
i had this trouble too. just set a firewall rule and turn off uPnP in azureus. to do this you will also have to set the router to give your PC the same ip address each time (done via its MAC address)
