Netgear dg834g (uPnP problem)
1 Dec 2004
S.Wales
Iv upgraded to the latest firmware, and i cant seem to get uPnP working, it seems to work for one pc in the house, but not the PC with Vista on it.
Im trying to use Azeureuz bit torrent client and usually i can whack any port number in there, do the test and uPnP will do its thing. but i get NAT errors, i have to manually add the ports into the router and forward them to my I.P.
Not a major problem but is this a known issue?
Hey
I had the same problem when I upgraded my DG834 to the latest firmware I had to go back to a later firmware to get it working again :(
almost certainly a problem with Vista, my Vista has a number of issues with uPnP apps.
I should say the software really, not vista. for example uTorrent does not work with uPnP in vista.
FWIW, my 834GT has the latest firmware and it works fine.
