- 7 Nov 2004
- On another planet
does anyone know if you can use DG834g v3 with be unlimited? i tried plugging mine in but it connects and tells me my line stats but no web pages load.
Typed the username and password correctly?
You don't need username and password to connect to Be*?
Have you cloned the MAC address of you Be* router?
nope,i know its worked with this router before because when i changed from my old isp the line was activated and this router worked but for some reason i put the bebox on.I tried a couple months ago to get the netgear to work again but i had same problem so i thought it must not be fully compatible
Iv got a sky branded (but unbranded/unlocked) DG834GT with DGTFirmware on my Be* connection, works fine and dandy for me.
