Netgear DGN2000, how can I tell if I'm interleaved or on Fastpath?
Man of Honour
13 Jul 2004
As title, with most routers there will be a WAN info screen that will give yopu this info, but I can't find it on my Netgear DGN2000.
Cheers.
Router status > connection status?
I dont have one to look at directly but its something like that i think.
That only seems to give me this:
Connection Time 00:03:03
Connecting to Server Connected
Negotiation Success
Authentication Success
Getting IP Addresses
Getting Network Mask 255.255.255.255
Connection time is low as I just installed custom firmware to see if that helped me find it :p
You need to go to Diagnostics > Display detailed ADSL driver informations
Then look for where it says channel it will either say Fast or Interleave.
/usr/sbin/adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 8000
Channel: FAST,;) Upstream rate = 1364 Kbps, Downstream rate = 15918 Kbps
Link Power State: L0
Mode: ADSL2+
Channel: Fast ;)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
