Netgear Extender Help !!!!
21 Jan 2013
Leeds
Hi,
Recently I was having trouble with my bt infinity so got the tech out and he fixed it and told me to get a wifi extender for my bedroom. So yesterday I bought a Netgear WN3500RP-100UKS and I am very impressed, I have it at the side of my computer wired through Ethernet.
So my main question is I want to connect my xbox one and ps4 to it through Ethernet for a more solid upload and download speed, but there is only one Ethernet port and that is currently on my new computer. Is there anything I can buy to add any more Ethernet ports to my netgear extender ?
thanks Dan
Firstly, you might want to err on the side of caution and remove the link to the competitor before a mod comes along.
Secondly, I'm fairly sure this: http://www.overclockers.co.uk/showproduct.php?prodid=NW-040-TP&groupid=46&catid=2316 is what you're after.
For anyone else who pops in, he has a Netgear WN3500RP.
Thank you
How would I connect that to my Netgear WN3500RP ? would I just use one of the ethenet ports on the TP-Link 5 Port Desktop Switch ? and then connect every thing off the TP-Link 5 Port Desktop Switch then ?
Thank you
Yeah, just that. Plug one of the ports from the switch into your range extender, and then use the free ports on the switch to connect to your devices.
Right would some one list the items I need to buy please ? Like the best Ethernet cables, need to connect pc xbox one and ps4.
