Hi Guys,
For many years I was using DrayTek Vigor 2850Vn VDSL/ADSL router.
This was instead of two devices like HG612 and Vodafone router.
Now I would like to change my DratTek because it giving me a random restart and can't handle all the devices I have at home I guess.
So, can you guys advise me what would be the best modem for 2020 to work well with Netgear AX12?
Also, I'm going back to BT, so I will get a brand new BT Smart Hub router, and this could be another solution connecting it as a modem only, but I'm not too sure if this device can act as a modem only.
Anyway, I'm looking to build a rock-solid connection at my home without a random restart and any connection breaks what so ever, so every advice is appreciated. Also, any suggestion to AX12 or better alternatives recommendation is also highly appreciated.
Also, it is worth to mention I need a router which can work with the mesh system so, for example, this AX12 is working well with EX7700 or EX8000 mesh extenders and this is the configuration I'm aiming for right now.
Many thanks
Kind Regards
Many thanks
Kind Regards
