Netgear or Bebox ?
27 Jan 2005
Letchworth Herts uk
Hi there I,m on Be using the Bebox ,and wondered if i would get a better speed/performance etc with a Netgear g834gt as i,m reading posts that the Bebox is not that great :confused:
I've got a BEbox and a nonwireless DG834, i find my connection is a lot more stable with the netgear than with the BE box but i need the wireless, getting the netgear with wireless built in next week so i'll see if it's any better with that too :)
I used a gt since it's release, and it served well for 4 years, better than that little box be gave me at any rate. However it was unable to hold connection on a 3db profile, had drop-outs and synced at practically the same speed it did on 6db. There's also know issues with heat, dropping lan connections and issues with it's interpenetration of the snr, possibly something to do with the unbelievably buggy firmware netgear somehow manages to produce.
I've since installed the new (beta) firmware on the box and it not only hold the line stable on 3db but syncs ~2meg faster (13.5-14meg vs 11-11.5) than my gt so it's now set to bridged, with a wrt54gl running tomato attached, and no lag. While the bebox lacks the resources to be a functional router, it's perfectly sable as a dedicated modem.
Not only is the 54gl a better router than the gt, but tomato firmware is infinity superior to the gt offerings which incidentally, haven't been actively developed for quite some time e.g. DGteams, a lot less features too. Qos is usually why people use tomato, but the various versions plus the ability to script almost any task means you can make it do virtually anything you need. You can actually make it do dual wan (a.k.a. line bonding) if you want, and that's not a bad feature for a £40 router :)
I used a gt for 4 years. I wish I'd used a gl for the past 4 years :(
The BeBox created a lot of issues for me. My previously rock solid line started dropping five times a night, speed issues, and so on. A switch to a DG834G cured it instantly. As did my 2091 and AM200. In summary, the BeBox sucks, and I have a great line so it wasn't hard for it to work with! :p
If you choose a DG, go for DGTeam's firmware. It's much better than Netgear's official one.
Stick with the netgear, keep the bebox in its box and hide it away somewhere or use it as a door stop.
