Netgear Problems :(
12 Jul 2010
Middlesbrough
I installed my netgear drivers last night for Windows 7, and it all shows perfectly and says it is installed correctly.
When I go to open the netgear software that helps connect to the internet it opens for a second and then closes. Anyone else ever had this problem?
Just for the record it worked perfectly last night until I had to reinstall Windows again due to problems.
Thanks,
ohh, shiiiii sorry, it was the WN111v2 adapter. But don't worry I went a bought a new Belkin adapter which works perfectly. The Netgear drivers werent adapted to work with W7 64bit, and this was confirmed by Netgear themselves :(
