Netgear R7000 - ddwrt VPN slow down
19 Oct 2002
Leicester
I brought an netgear R7000 due to my SH3 having really poor wifi single at home.
Also brought it with intention to install dd-wrt and use openvpn to protect my whole network.
Installed dd-wrt all fine and openvpn with PIA but when i connect to PIA it kills my download speed (on virgin 200).
Download is max 40-50mb. As soon as i disable the vpn on the router it goes straight back upto max speed.
Cant understand why? Using the PIA client on windows normally i still can get max speed.
I `think`that openvpn is mainly single core optimised???
I read that somewhere that for full speed you need a pc based router setup like pfsense
Reading about looks like even with a dual core 1GHz just not fast enough to handle fast VPN connections....nor can i find anything that can run at full speed :(
The router in question lacks a hardware FPU, it therefore has to do software FPU emulation for encryption and that sucks. This is why you don't run meaningful encryption on a router that lacks hardware acceleration. You have options, they basically involve using a better router that will support hardware acceleration (read not a consumer grade box) or build one, the other option is you use crappy encryption and increase speed that way. Your choice.
You need something like this with pfSense installed as said above. The linked box (no endorsement, it's just one I've seen on pfSense forums before) has a Braswell CPU with a 1.6GHz/2GHz clockspeed and crucially it supports AES-NI. This means it can process OpenVPN encryption in hardware and should give you practically line speed if set up correctly. It has 2GB of RAM (ample for a router) and a 32GB SSD (again, overkill) included. You'd need to learn a little about setting up pfSense and OpenVPN but there are lots of guides around.
Edited to add: That case is ugly, but it's fanless and the whole box is only 10 watts maximum. The company (Qotom) do a lower, slimmer router case with 4 Intel NICs so if you contact them I'm sure they'd be able to oblige with a custom box. They sell a dizzying array of case/config options so I'm sure it's doable. You only need the two NICs btw. One for WAN in (from the SuperHub) and one for LAN out to a switch. I have a similar setup which goes SH3 > pfSense box > gigabit PoE switch | Ubiquiti Unifi UAC Pro | wired clients. Rock solid.
Ouch at the shipping though:eek:
Haha I didn't see that, I just grabbed the first one I saw. There are dozens of others so feel free to dig around. Even at £160 inc it's cheap for a fast capable router with a decent amount of RAM and an SSD. It's in a metal case also so it'll last years. I'm currently sat in Mallorca on holiday so I've given everything I can be bothered to. As you were. :p
I've Been after a small pfsense box too that's a decent price... Still looking!
Pfsense hardware they sell s bit over my budget
:D
Enjoy your holiday m8
Looked at similar small pcs a while back but looked a bit too complicated for me,ended up with a netgear 6400 running ddwrt and using openvpn client
I only have a max 3.5 meg line so easily copes with the speed lol
