Somehow... the AC adapter for my Netgear router has gone missing and I am now in need of a new one. Anyway I know that the output rating for it is supposed to be 12V 1A, but I have sourced another adapter which is rated at 20V 2A. I've attempted to test it and it seems to power the router fine but is it ok to use as a perminant replacement or is it not and needs to be strictly 12V 1A and it could blow the router up if I use the incorrect rated adapter? I know adapters which are rated lower do not work properly or do not work at all as I tested another one which was only rated at 9A and it kept turning the router on/off/on again.
Thanks all - Liam
Thanks all - Liam
on a 12volt router.STOP using right now unless you want to fry it
