Netgear WG302 v2
Caporegime
21 Apr 2004
Bristol
Hi,
Tried hard reset but I can not for the life of me connect to it through Wireless/Cable - tried multitude of PC's and Cables. So I would presume it's buggered. Or is there anything left to do?
Flash the firmware to the latest revision. Even if it has the latest revision flash it anyway because sometimes they just go mad and need the firmware reinstalling. This is usually the fault that causes the problem you describe on these routers.
