netgear wg311v3 MAJOR PROBLEM
1 Jan 2009
hi
i just purchased the netgear wg311v3 pci wirless card
http://www.overclockers.co.uk/showproduct.php?prodid=NW-011-NG&tool=3
i installed the software first like the manual said, turned off my computer, installed the pci card into my available pci slot and then turned my computer back on.
now in the manual it says that the netgear software will automatically load and then install the card for you.. this didnt happen so i went around finding the program on my computer.. i load that up and well nothing happens, i try downloading a newer version of the netgear software but there is the still the same problem.
has any1 for any ideas of tips please
ps i have installed wireless cards perfectly before in other pc's so its not that i have not installed the card properly into the pc itself
thanks
A long shot but does the pci slot have to be enabled in the bios - i know in my case sata connections and a pci slot came already disabled so i had to enable them to use them.
