Netgear wireless access.
30 Sep 2008
Ok so ive setup a new Netgear cable router.
First thing i did was disable wirelees /PIN option.
Soon as my Windows 7 machine tries to connect, it comes up with "you may need to select a certificate or enter a username or password to connect to this network".
choice of either enter name/password (ala Windows login style) or try a different network.
Other Win7 machine works fine
Xbox works fine
Tried WPS/PSK, WEP 128bit
Tried different channel.
Reinstalled WLAN drivers.
Its an issue with Windows 7 but never seen it before.
