Hi all,
I've got my Netgear rangemax wireless modem router (dg834pn 108mbps), and on my desktop a Netgear rangemax wireless pci card (wpn311 108mbps). I'm using a 2mb connection through Plusnet.
Now on my pc the netgear wireless assistant shows the connection as being between 48mbps & 54mbps (thought it should be 108mbps), whereas the wireless network connection status states that the connection as being 108mbps.
1) is this correct? 2) if not how do i change any settings to get a faster connection?
Thanks in advance
ps i'm on the first floor of the house no more than 15ft away from the router, of which it's on the ground floor on a high shelf if that helps.
Thanks in advance
