- 19 Jul 2004
Hi all, the WAN light on my router went orange last night.
Logged into it the IP was 0.0.0.0
Plugged the cable modem into a PC and the PC got a IP 81.X.X.X
Reset router to default settings this made no difference.
Upgraded to new Firmware this made no difference either.
Plugged modem back into PC typed ipconfig /all
Put the IP into the Router under static settings... the WAN light turned green but all PC's connected to it say local only connection.
So Modem to PC all is fine.
Modem to router then PC is borked! This is the 2nd time ive had this with a netgear anybody got any ideas?
Gaz
Gaz
