netmahal Removal?
5 Mar 2007
Macclesfield
Hello,
A friend has managed to acquire the "netmahal" virus, I've had a quick go at removing it and have failed! It's Windows 8.1 and the virus stops the "Change PC Settings" screen appearing (I was going to do a system refresh as there is lots of crap and a refresh would be a good idea).
I also can't re-boot in safe mode...same problem as above!
Can anyone help me (please!) the guides i have found ask to boot into safe mode...
Thanks,
Most viruses can be beaten by starting windows, press reset before it starts completely. It will then ask you if you like to restore.
I didn't know that...will try it when I get to my mates
(think a re-fresh will be a good idea...)
Thanks All
For future reference a combination of Malwarebytes and Combofix.exe fix the majority of things.
If neither of those two work then a clean install is the normal next step. You can try a system restore before but this rarely works. Always worth a go though before giving in and clean installing.
