- 25 May 2009
- Derbyshire
Aghhh - stress over for now.
A 'friend' has used my tosh laptop without asking and has aquired a multitude of infections (so he says) starting with netsky worm. He was using ebuddy or something as I don't allow msn on the machine as the people who use it aren't 'savvy' enough not to get problems.
Basically avg told him the machine was infected and to run a full system scan. He did and rebooted but everytime he tried to log in to windows it instantly logs out. Trying to be clever he then tried safe mode which let him in, ran the scan with auto repair and restarted. Then it logs out instantly no matter ehat mode it's started in.
All this is third hand info as he's done a bunk and I'm left to pick up the peices. It looks like he disabled all the AV etc for some reason and downloaded some pictures of his GF, prob semi naked as is the wont with most 15yr olds.
I can't log into windos to try and sort this as even my admin password instantly logs out. I've tried all the safe mode options as well as system restore (is was worth a try). I have an xp key for the machine, it's a tosh laptop, but no discs and as far as I can tell no restore partition. Someone else has also dumped about 4gb worth of pictures onto the machine the day before and deleted them off their mem stick and would like them back.....
Can anyone help? If it was a desktop and I had the win install disc I'd prob just connect to another machine, scan for issues and copy the photo's and any other stuff added since last back up and then format, put it back into the desktop and reinstall.
Can donate some beer tokens to anyone who can help me get this sorted.
ta
craig
ta
craig
