Network advice
23 Oct 2009
Rotherham, S. Yorks
My mate has recently bought a Cinema System (LG-HX806SH), this has one NIC and from what I can see no WiFi support. Their computers are upstairs connected via LAN to their VM Router\Modem. I need to connect the Cinema System to their Network. I'm thinking the best way would be something like http://www.tp-link.com/en/products/details/?model=TL-WA701ND#spec which has one LAN port for the Cinema System to connect to.
My mates wife also uses a Tablet so this would also give her a better signal downstairs.
Opinions on this or would a homeplug be the best way to go, £23 sounds good.
Regards
Craig
Homeplug if you want it wired. If you want better wirelss in the house then first try changing the channel on the router or just change the existing router for something like the Asus RT-N56U.
