- 25 Feb 2016
I'm installing a hikvision CCTV system. I made a network cable for one of the cameras. After first attaching one rj45 the wrong way round, I redid it, and the cable tester suggests the cable is fine. Sadly it doesn't work. The camera plugged into the NVR doesn't power up or show up.
With the pre made cable I was using to test it works fine.
Is it the type of cable I'm using? The cameras are PoE. Or is it not correctly made? The cable tester lights up in sequence for all 8 strands, which is confusing me.
