Network cable to garden office?
It will be cheaper to buy a krone tool (as cat6 should be patch panelled not crimped into plugs) than it would buying a premade cable.
Krone tools are about £3 which will do the job. Most patch panels are colour coded and you can watch a few youtube videos to learn it.
No.
I'd need a really good reason to use SWA for a surface clipped cable. If it's surface clipped it'd shouldn't be difficult to replace even if it did get damaged.
